Ford Pre Crossflow Motor fra Seven S2
Indlægaf Seven7 skrevet 3. apr 2023, 23:30
Skal du have den rigtige motor til din Seven S2? Så er chansen her nu. Den rigtige motor til en S2 i stedet for en Crossflow.
Bored to 1398, 109E Three Bearing main, Lined bored with Solid steel main caps, 0,060 oversize Hepolite 18400 Pistions
Camshaft Piper BP270, Duplex Timing gear, Steel crankshaft, ported head with 1500 valves, Including an Sets of dual 45mm webbers.
Engine is fully balanced
Power Band 1800-6500, output 120hk
Engine have little use and are ready for action
Made by Brian Melville specialised Engine LTD
Engine was fitted to Mike Robotten Hill Climb winning Lotus Seven S2
Solgt
Seven7
Tilmeldt: 23. jan 2006, 23:04
Geografisk sted: odense SV
Medlemsnummer: 114
Tilbage til Reservedele
